O
oregonxjman
Guest
The TPS may test out fine, but they have been found to have a glitch in them. The vacuum solenoid could cause a little bit of a high idle, but that is because it's causing the engine to run lean. I still think you should take it in to your local Jeep dealer, and if the TPS recall has not been preformed on your vehicle, have it done. As a matter of fact, you can get a report on all outstanding recalls on your vehicle, and have the dealer do these recalls.
