gtpolkus said:Hi guys
Vibrations at 50-60 mph always point to an imbalance in the "rotating mass", ie your tire because of the nature of the suspension
Natural frequencies of suspension systems are usually in the area of 10 Hz, very low because of the relatively low spring rates of your suspension (compared to your unibody). 55MPH on a jeep running a stock 225 tire, (27"ish inches) is a rotating frequency of 11.5 Hz (rotations/sec). You're hitting a resonance frequency because you're right around the natural frequecy of the suspension of the car. Balance the imbalance and your problem is solved. Bearing, out of round tires, improper balance, bent rims, etc
Greg
Hey thanks for the explination.
