DurbElites
- Simi Valley
95 xj 4.0 184000 on the clock. replaced the sending unit about ten times now because oil leaks through the unit to the connections about 5 mins after running, finally got one that works and my oil pressure has been creaping up to around 35-40 at idle over the last month from 20, now it jumped to 60 at idle and all through the rev range. sea foamed the motor and it dropped back down to about 40 at idle. any ideas as to what the problem might be?? i read something about a regulator in the oil pump that can get stuck? potential of being the problem????
