dan1977p
- Virginia Beach, VA
I'd like a little help reading this gauge. It's hooked up to my brake booster line and I'm at about 4400' ASL. I'm running it because I feel like it's running rough but every time I find and fix a leak in a vac line, it doesn't seem to change much.
Tuneup with Champion plugs, new cap, rotor, plug wires, NTK O2 sensor, fuel filter. Compression was high 120's and pretty even last I checked. Fuel pressure was good too after I replaced the regulator.
New injectors. Smoothed out significantly after that.
New motor and trans mount.
Started after new motor mounts. They were only thing installed when this happened so I'm sure the mounts are letting it shake, but I wonder if there is an underlying problem causing the shake. Unfortunately, this video isn't as bad as it has been lately. Usually I get enough shake that I think the downpipe rattles against the oil pan.
I'm thinking a valve job wouldn't be a bad idea here.
