jdurbach
- Centennial
how did you pull that off with leaving the shafts in?
dinorl007 said:in the past i have also changed the u joint in the front axle shaft while they were on the jeep, it takes some finesse and patience but it can be done, if u can remove the axle without a lot of trouble it will be easier on a bench, if the old joint is seized really bad, u can cut them apart with a torch, if u do this make sure u only cut the joint and keep the heat off of the ears, when u cut the joint apart it will pop and spew grease so be careful, as mentioned before, apply antiseize when installing the new joints it will make it easier to get together and apart in the future good luck
iwannadie said:I read you should never use any type of anti sieze on the ujoints. It will just allow the caps to spin in the ears and eventually fail?
Heat will help with the hub nut too. If the cotter pin is rusted solid, don't worry. It's soft. You can chisel it off, or the nut will just shear through it as you unscrew. PUnch or drill the residue out of the shaft after it's off.anodyne33 said:Wow. That sucks. My bolts came out just fine the first time I did mine, but getting the hub out was the bitch. You need to go to the blue wrench. MAPP gas is supposedly much hotter, but alternating propane and quenching with PB has worked for me on several other fasteners.
Oh, and I assume you're using a big breaker bar? I had a heavy 1/2"er to get those out. You may have to throw a cheater on there also.
As for the hub nut, I've no suggestion.
iwannadie said:When I did my shaft Ujoint, they were factory original and just fused in place lol no rust though. I beat them with a hammer and socket, I used a C clamp, I bought the HBF tool and nothing worked.
I gave up and took the shaft to a lube shop to have them press it out, they bent the ears... What I thought was going to be an easy afternoon(both sides) fix turned into a mess for me lol. Getting the shafts out wasnt too bad, the giant axle nut wasnt a problem. The ujoint defeated me though.
Interesting process. I had to read it twice to envision what you're talking about. I've never bent the yoke changing a U-joint, but I'm always willing to try something new. I'll give that a shot next time. Instead of a peice of channel I'll probably stand the arbor plates on their sides and use the cut-out sections to cradle the u-joint.lawsoncl said:It's very easy to bend or brake the ears if you're not doing it right.
For removal, I've found the best method with a press is to have a piece of u-channel underneath supporting the cross of u-joint and a big socket above to push the cap into. No socket underneath. That way, the force is pushing the cross and the upper cap upwards into the socket. This cuts the force in half as you're just pushing out one side at a time, and you're not squeezing the axle shaft ears together which just bends them and makes it even harder to press out the u-joint.
