This is being sold as is, as needing finishing work to get on the trail. It is pretty much all there. Just needs a little bit of Final work to get done.
Jeep MJ (clear CO title) 4.0 aw4 241 - 4:1 and 2low.
King Pin HP60 front. stock (have carrier and 4.10 gears to go with it) COMPLETE
FF14bolt. Stock, artec truss (have 4.10 gears to go with it) no brakes, was stripped for discs
The bed has been removed, tubed, and linked.
Tri-4link rear with airtech 14" coilovers,
3 link front w/tracbar.
full exo, sliders, xj fuel tank raised above "bulkhead" at back of cab. Storage bins, high lift jack/mounts.
39" red label krawlers. 2 are 17-18/32, 2 are 12-13/32, one slow leaks in a day, two no leaks, and one barely leaks (lost 10psi in a month?)
Mounted on soft 8 steelies.
Interior has race style seats, 4point harnesses, stock dash
hyrdo assist set up
8k winch.
Needs gears/lockers, brakes completed and plumbed.
Needs 3link front finished, Is a roller on coils up front but buckets were welded on with intent to run coilovers. Would need to rework mounts to maintain coils or upper mount for coilovers.
Rear is set, just needs sinched up.
Set up in pics at about 113" Wheelbase.
Plenty other pics. Have pics of the rig out and wheeling on smaller axles and 37's as well.
call is best option.
LED:
719 660 8268
price: $5000.
