D70XJ
- Columbia, Mo
Thats for sure. A buddy of mine ended up with a big crack in the unibody of his XJ after about 6 trips while running boggers and fullwidths on a 44/9". I also heard you cracked a windshield while flexing out too. Ouch. Thats part of the reason i decided to do a cage right away, i can already tell it stiffened the chassis quite a bit, and hopefully will head off the unibody flex problem before cracks and creases develop.You will find out that the unibody does flex a lot due to the heavy axles.
BTW how do you like the 3 link coil setup in the rear of yours? I may be doing something similar in the future when time permits. Same friend who cracked his unibody ended up 4 linking the rear with coils and said it made a huge difference in getting traction and in hill climbing. I can definently see that it would damn near do away with any wheel hop in the rear.
