transmission mount problem
Ba-Riedo
has frame envy
I went to change my trans mount today because I have my T&T customs belly pan off to do some repairs on it. I took the old mount off and placed it side by side the new one and noticed a difference in height.
Kinda hard to tell in the pictures but the new one is a little taller, so is this normal and will it shrink down when I put pressure on it? Or did I get the wrong one at Schucks?:doh:
-Alex
normal-- the rubber compresses with age and weight.
I swapped an old one for a new one and developed the need for T.C. drop bracket/SYE-- the angle changed just enough to start vibes after the change:gonnablow
You are just fine with that mount, it will compress a bit with the weight of the drivetrain! Why not a good poly mont though?
I am considering going poly on the transmission and motor mounts, my jeep being my DD, will there be more vibration than normal? am I better off with rubber mounts on both?
Thanks
89 XJ 2dr 103K miles exceptional condition.
