Transmission cooler questions
BIGSLVRXJ
Des Moines, Iowa
Trying to diagnose tranny troubles on my AW4. I just put a new radiator in that had a tranny cooler built it. If I take the return line off and crank the engine nothing spurts out of the bottom of the cooler. Does this mean the cooler is blocked? Anyone know? TIA for the help.
Don't know. Anything come out of the pressure line?
I got it figured out, I just wasn't cranking it enough times. Anyway I've got good flow there so I know its nothing I did with the radiator that screwed my tranny up, it must be something else. There's no way the transmission cooler can malfunction is there? It just needs airflow right?
