Erik Litchy
- Pekin IL
pics
http://www.divshare.com/download/5086265-773
http://www.divshare.com/download/5086213-772
problem is large large slack shifting from forward to reverse, and its in the transfer case. it also makes grinding noise on engine braking in 2wd. you can see it has run low on fluid before. chain is ok but ill replace it. what else is likely to be worn? it shifed fine (smoothly), but sometimes it delayed going from high range to 2wd.
also http://www.divshare.com/download/5086395-3b4
