transfer case drain and fill plugs stuck frozen
The ATF inside could be doing it's job and sucking up the heat. Although 5 minutes sounds like plenty.
Maybe that Royal Purple stuff really is better at that ...
Figured I would give an update since I finally got them off.
Let it sit for a while, put the propane torch on the fill plug for 10 minutes with the valve all the way open, sprayed a shot of penetrating fluid, put allen socket in plug, tap it with a hammer, hook breaker bar to it and use my legs to turn it while on a creeper like I was doing a squat.
"POP"
Repeat for drain plug and replace with
http://naxja.org/forum/showthread.php?t=1075659
