Hi all,
Installing a trans temp gauge and need a 12V Ignition Source to run it. For a 2000, is there a good ignition-controlled 12V source that you recommend in the vicinity of the center console?
Also, very basic question... how would I use a multimeter to check for 12V? Drive a pin into the wire and touch the other pin to a ground?
