crash02
- hemet/san jacinto
I noticed that resistor on mine, but I don't recall seeing it on the FSM drawings. IIRC I back tracked it once and discovered that it is a bleed resistor to drain voltage in the brake sensor wires once the voltage feed is opened (removed, switch off) from the brake to TCU wire. If that resistor is bad I think it causes TC lock, unlock issues. I never found the resistor value marked on mine, nor listed in the FSM, so that is great data to have!!!! Might be worth a stick note!!!
here is the thread where I found it. Post #31
http://www.naxja.org/forum/showthread.php?t=1028593&page=3
