solomon7
- Portland OR
On the tranny side of one of the cooler lines, where the rubber hose meets the hard line to the trans there is a tiny pinhole in the silver outer sheath of the disconnect. A tiny bit of fluid seeps from it.
Would somehting like JB weld work for a tiny hole like that or do I need to replace the whole thing?
In the first post it's a tiny pinhole almost right below the spot the upper right arrow is pointing at in one of the "crease/crimps"
http://www.cherokeeforum.com/f2/transmission-cooler-line-leak-question-fix-30509/
