Dent Doctor
- Erie, PA
Alright guys I have scratched my head long enough, so here is the story. I have a
1998 Cherokee 137,000 miles
6" lift, 35's, and Rhino'd exterior
So the problem I have been having for a long, long time. I have no Overdrive when I run down the road. I have replaced the TPS(Throttle Position Sensor), IACV(Idle Air Control Valve, NSS (Neutral Safety Switch), and TCM (Transmission Computer) and with no avail I still have the problems. I have re-grounded the block, the battery, and 4 wires next to the Computer behind the drivers headlight (not sure if that is the PCM or ECU. Pretty sure it's the ECU but I don't know. So after all that the only way that I CAN get it into overdrive is by driving down the road at around 50mph and turning the key off and back on again. Then for around 1/2 of a mile I can have overdrive. Seeing as how I drive everyday 25 miles one way this isn't a very efficient vehicle without OD. Any suggestions, Comments, or Rants will be greatly appreciated. One more thing I did get the codes pulled. The codes I pulled were:
Eng: 26/P0122 (TPS Voltage Low)
Eng: 137/P0700 (EATX Fault Present) *I read this was linked to TCM
I have looked through the wiring diagram in my Haynes Manual and I do see the TPS and TCM are both connected by a single power wire but there are 3 other sensors connected between them that I would think would pull a code also. I could be wrong though, those three are: Coolant Temp Sensor (temp gauge works), Air Temp Sensor, Heated Oxygen Sensor.
