chevelle01969
- Huntsville, Alabama
I always like to take a peice of pipe that just fits around the rachet handle or a breaker bar for leverage. It helps for those stuborn nuts and bolts.
themangeraaad said:well, i know the 32mm socket was mentioned for the hub nut... on the 30 its actually a 36mm... Believe me.. I just had to go pay 10$ for one.
But anyway, yeah, 36mm for that, sockets necesary for removing the front hub assembly, Tcase, driveshafts, one for removing the yoke from the rear driveshaft (I forget the size, that may be a 32, though I dont think so, ill check later), spare yoke if you can (mine has come in helpful, though a yoke shouldnt be the first thing to go in the axle)...
And for flaring tool and tube cutter... to keep it small you can just get the mini tube cutter and compression fittings, they work well and dont take up nearly as much room as the flaring tool. Just throw them in a toolbox and forget, make sure to have a few, and make sure to have the right size
ren said:2 quick Questions:
1) how do you keep all of that stuff from jumping around and maybe hitting someone?
2) did you know that the roll of t/p will fit in the glove box if you squish it a little?
