Dzldust
- Jacksonville,Florida
1996 Jeep XJ built for light trails so previous owner wasn’t worried about street manners just Offroad performance,I decided after a thrilling highway ride to add the sway bar back to front since this will be 90% street driven with some light trails and beach time .PO installed some nice parts including a Ruff Stuff track bar setup,only thing was it’s the bracket for “wider” axles so it hangs off frame enough that factory sway bar will not clear , No way around it,factory sway bar will not work,it’s 34” wide inside to inside,I need atleast a sway bar 36” wide to clear this bracket.
Possible Solution: find a wider sway bar?
Another solid solution but one I’d rather not do : cut it all off and weld in the Track bar bracket for stock axle width and shorten track bar.
Rather find a wider sway bar,anybody ever run into this ?
