Plans have changed and I need to clear the garage.
All items in Andover ks
d.d. machine dana 300 flip kit $70
thread: http://www.pirate4x4.com/forum/showthread.php?t=505924
Package deal for axles and wheels $2000
A set of 4 trail ready beadlocks. 5x5.5 15x8 aluminum 3.25" backspace - $650 obo
There is some rock rash on the rings but they still clean up nicely.
$1550 obo for both axles
both built 1.5 years ago (new brakes seals ball joints etc.))
78 ford Front HP Dana 44:
yukon 4340 axles shafts with yukon super joints
stage 8 x-lock spindle nuts
5.13 gears
detroit locker
warn premium hubs
reid racing/dedenbear knuckles
4-bolt high steer arms for 1 ton TRE (can be drilled for heims)
beafed up dif cover
setup for leaf springs
setup for hydro assist
no shock brackets
78 ford 9 inch
yukon 1541 axle shafts
full spool
5.13 gears
disc brakes
back side of housing beafed up
no shock brackets or spring brackets
cj2a windshield frame. Needs some work filling holes that were drilled in it by previous owner but has good glass. $50 obo
dj3a tub and frame. frame has been cleaned of brackets and boxed. The tub will need one floor board replaced. It was cut to fit a l6 and had the dash cut out of it (still have it though) to put in an aluminum one. $300 obo
These picture are of it all together but it is currently all apart. I would included axles tires and wheels if those were wanted too.
partial trades considered for aluminum 15x8 5x4.5 wheels, hp non disco dana 30, 29 spline chro 8.25, xj or tj dana 44
5.13 gears
detroit locker
warn premium hubs
beafed up dif cover
no shock brackets
78 ford 9 inch
full spool
5.13 gears
disc brakes
