Hopelessredneck
- Abbotsford BC Canada
So I bought a 97 XJ country it came with a seized 4.0 I have a good 4.0l from a zj so I was unable to pull the tc with the transmission it had to stay with the engine due to not being able to get the tc bolts out of the flex plate till i pulled the crank out of the block but now the tc won go back on to the aw4 no matter how much I spin wiggle and push on the tc it won’t spline on. This it the exact same tc that was on the trans when the engine was bolted to the trans. I found that the inner imput shaft will spin by hand but the outer one will not spin at all even with a pair of Chanel lock pliers on it (with a rag in between to protect the splines) I’m at a loss here any help would be a huge help as in not to familiar with the aw4
