I also like the twisties. We have some great little roads in the hills out here. I'm not really into the "look" just to have it, so I went the locker route at stock height. PowerTrax Limited Slip, new stock rear springs to get it back up where it belonged, removed rear sway, good Monroe shocks, Poly bushings on the front sway bar ends. Bought 235 / 70 R15 Firestone Destination A/T from TireRack (same hight as stock 215 / 75's but an inch wider).
It corners much better than it "should" and with the locker it really hunkers down when I nail it around the corners. The tires just got replaced at 35,000 miles, but it was well worth it for the fun value. I just replaced the tires with 75 series Destination A/T's which are an inch taller. Great traction off road by the way.
1996, 2 w.d., 4 cyl., manual trans, 2 door, added factory skids and hitch for a lower C.O.G. and because I could.
