To Do List
Got my dana 44 rear disc brake conversion ON. But axle seals were leaking. Last weekend replaced the timken axle seals for the skf seals, should be good now. Tonight changed from 7100 shocks for stiffer valved 7100s. Changed the 3 chamber magnaflow to the straight through magna flow muffler. The 3 chamber magnaflow was pretty much melting my floor and dynamat on the inside of the jeep. Need to finish wiring some lights and do oil changes and misc things... 1 month away for a fun adventure in MOAB
Uber sexy steering done.
mac ‘finally to a point that i can make a list’ gyvr
Just retired (August 31) looked over the XJ, rebuilt the fence between my house and the neighbor's and now I will start checking out the little shit. Oil change, pull the rear brakes apart, repair or replace, change the diff fluid front and rear, decide if the noises I hear when I drive around town are a U-joint or not, replace the transmission fluid (at least as much as I can drain and the filter), replace the transfer case fluid, and stock up on some rare bourbon for the evenings around the campfire (don't forget the approved ring, or in my case a Webber charcoal grill and a bunch of cut ends from construction. It works really well.
Need to put a floor in mine, and rear bumper/tire carrier install.
All the metal is in hand....or here ,nothing in hand yet, will keep gloves on
Don't need any blood loss...
I've got to
Install front locker/alloy shafts
Install ruffstuff 3/4 hiem steering
Install 12v accessories plug
Locate some d35 shafts for spares. I'm surprised how hard they are to come by.
Maybe tie my muffler up so my manifold doesn't crack.
I could possibly bring a set with me.
Sent from my SM-G892A using Tapatalk
3 weekends remaining means squeezing in a couple hours after work with my pops.
Long list of stuff still remains.
Sent from my SM-N950U using Tapatalk
Update
CAD delete/Install front locker/alloy shafts
DONE------Install ruffstuff 3/4 hiem steering
DONE------Install 12v accessories plug
instal none broken driver's seat DONE BUT IT SUCKS AND IM GOING TO HAVE TO TRY AGAIN WITH A DIFFERENT SEAT.
maybe Install my viar compressor I bought 9 years ago and never did anything with.
I’m aligned and back on all 4 tires!
Drives pretty good now on these 35s!
mac ‘list of little things left’ gyvr
Nice!!!
Look forward to seeing this in person, been debating on the MC stuff.
Looking forward to meeting you!
The MC stuff is really nice...and REALLY expensive!
mac 'cabin 51' gyvr
Shakedown run next weekend.
mac ‘about there’ gyvr
Necessary:
Fab angle iron battery box and tie down bolts
Transmission Temp Gauge sending unit
Front axle vent tube
Exhaust pipe hanger
fix radiator hose - power steering line interference
wrap and secure aux wiring for winch and lights
Retorque everything and make list of needed sockets and specialty wrenches.
Inventory tools and trail spares.
Hilift Jack mount under rear seat
Maybe:
paint roof
paint roof rack
fix heater blend door
Headliner
Remote entry module
]Update
DONE------CAD delete/Install front locker/alloy shafts
DONE------maybe Install my viar compressor I bought 9 years ago and never did anything with.
Needed:
-BUMP STOPS
-SLEEPING PLATFORM
-BALANCE BEADS
-MOUNT COMPRESSOR
-TRANSFER CASE SKID
-TRIM TRACK BAR MOUNT
-Install CB
-Parking brakes
-Tire carrier
Maybe:
-Fix roof hole
-Repaint sliders/fix door dent
-Rear shocks
