NJblackdeath4x4
- Fords NJ
I know this is a Cherokee forum but if I'm not mistaken my brother's TJ has the same 4.0 that my XJ does, and the two Jeeps operate the same way so I'm confident you guys will be able to steer me in the right direction again.
So his TJ won't start at all. I turn the key and it immediately bogs down and cranks like a dying pig then quits. If I hold the key long enough I can smell gas, so I don't believe it's a fuel delivery problem. I tried hooking up jumper cables in case the battery was about dead and it gave it a healthier crank but still would cut out after a couple seconds. So I also don't think it's lacking electricity.
I guess my next step is to check the spark plugs or wires? What do you guys think?
