RTFM
- Southern I-De-Ho
http://www.expeditionexchange.com/equal/
Equal is a dry polymer that can be injected into tires directly through the valve stem or placed into the tire cavity before the tire is mounted. Once inside the tire cavity, centrifugal force moves the Equal across the tread width and around the circumference of the tire, responding to force variations caused by irregularities within the tire, the road, and even the load. As the tires and wheels spin, Equal constantly repositions inside the tire as the load and speed change to maintain a stable footprint without vibrations.
The improvement over lead weights will be obvious the first time you get behind the wheel. You'll feel less shimmy, bouncing, and vibration. The ride with Equal balancing your tires is smooth, comfortable, and stable. Even more important than a better ride is a better bottom line. Equal will save you money. Even wear means thousands of extra miles on each and every tire. Less shimmy means fewer alignments and fewer component and maintenance problems caused by vibration. And a one-time installation of Equal means you'll never have to pay to re-balance the tire again. Ever. Still not convinced? Try it. Drive it for a day and you'll immediately feel how well Equal works. Drive Equal for a while and you will see how dramatically Equal reduces tire wear. Just try Equal and you will never mount another tire without it.
