They will fit easily if you trim the fenders for YJ, TJ, or similar flares. They probably could fit if you trim the inside of the fenders (below/inside the stock flares) and bumpstop them.
If you run stock wheels you will probably have significantly more issues with clearance while turning and/or stuffing. They would work much better on a wheel with more off set (3.75-4.25 of Back Spacing).
