Ok regular driving any speed no grinding or vibration.
If I barely press the gas pedal say 1/4 in then I get a constant vibration until l let off gas or press it further.
Coming to a hard stop a bad grinding vibration from the front end that will go away if I let off the brakes and then easily reapply them. Now the vibration and grinding sound does not start till your at about 10 mph decelerating in the stopping process.
I have checked unit bearings, brake rotors and pads for rocks or other foreign objects, lug nuts for tightness. Now I don't remember it doing this before I put on wheel adapters and 17" moabs with new tires. Balance on tires is good.
So I have 4.5 in la lift, sye, 4.56 gears Aussie lockers, 5 on 4.5 to 5 on 5 wheel adapters,
Going to go out and try moving my yoke around and see if pinion has any play.
Just looking to see if anyone else has had this or other ideas on what to check.
Thanks
Thanks
