Hi,
All the threads I have looked at talk about the thermo (electric) fan not coming on. My problem is that it won't switch off.
Happened once before and I walked away expecting it to shut off once it had cooled down enough, I had been having overheating problems but since solved by replacing the blocked radiator. At that time I came back to find the battery flat.
Didn't happen again until......
A few weeks later now and I switched off after arriving home and the fan kept running (something I don't recall normally happening even after 14 years of ownership).
Went back out a while later and still running, so I disconnected it. The next morning before starting up I reconnected it again and it still wanted to run.
I suspect something to do with a controller or thermo switch but would like to know before I start replacing parts based on a guess.
Thanks,
Guzzi
Thanks,
Guzzi
