ashmanjeepxj
- Vail AZ, Jimmy's Cherokee Buggy
wrecked said:Thats actually quite interesting. How is the shackle in the rear more reliable? You mentioned that it would have more brake dive and would require a long slip shaft on my front drive shaft, I'm not quite understanding how the shackle in the rear is more reliable?
I can see the front suspension compressing when trying to climb an obstacle(like a wall) with a rear shackle. Where as a front would try to decompress.
Little bit confused which way to go.
-Kevin
This is what happens.
When going down a steep hill or hitting something at speed the axle pushes back and the shackle allows it to more back and bend the rear section of hte main leaf. check out this viedo of the little hill I wnt down that bent that main leaf. Not a worthy obsticle to cause carage...
VIDEO DOWN KISSING ROCK, BENDS THE LEAF
VIDEO UP KISSING ROCK
VIDEO UP "local" DUMP BUMP WITH BENT LEAF
With the shackle in front the axle pulls on the front spring hanger rather then pushing. more reliable.
With the shackle in back as the axle drops the shackle swings forward further from the T-case so you need a longer then stock slip drive shaft or a center limit strap. With shackle in front the shackle will swing back twards the t-case on down travel so a stock drive shaft could be used.
Toyotas are stock with shackle in back and have a normal slip drive shaft but you but somen flexyspring on it and you quicly will over extend the shaft. Square drive shafts are a common cheap fix. Ive run square shafts front or rear, it works but its noisey and has soem binding, but for free...its an option.
