No rust 2001 Cherokee for sale. Dad bought new, iv'e owned about ten year's. Most of the upgrades have been over the past four year's. List of mod's are as follow.....Rebuilt engine at Tex-On Motor's in HOTX 11/16. 3yr/36K warranty. Still under the mileage. Banks header, Magnaflow Y-pipe, Flowmaster muffler, replaced O2 sensors. All sensor's on throttle body were replaced with dealership part's. I installed a new radiator, rubber grommets below radiator, electric fan, clutch fan, new hoses. Metal hood vent's. Replaced starter, water pump, Hesco high flow thermostat housing, 2001 Durango master cylinder, alternator, power steering pump, p/s lines, serp. belt, idler pulley, coil pack bar and recent plug's. Four hole fuel injector's. Big tranny cooler on front of radiator. Front 1999 H/P Dana 30, Vanco big brake kit for 16" wheel's. New wheel hub's, Spicer ball joint's, Moog factory steering, 4.56 gear's, Ruff Stuff diff. cover. Rear is the 2001 8.25 with 4.56 gear's, Detroit TrueTrac, Ten Factory chromo shaft's, Ruff Stuff diff. cover. Rebuilt 231J with wide chain, 6 pinion Planetary and SYE. Rear C/V driveshaft from Adam's Driveshaft. Replaced transmission mount. I dropped the gas tank and replaced with a dealership fuel pump, replaced fuel fill hose and vent hose. New clamp's. Sway bar disconnect's. MetalCloak 3.5" lift and there big bolt aluminum hex adjustable upper/lower control arm's. H.D. Offroad shackle relocation box. 3/4" longer than stock shackle's. Bilstein shock's. Longer brake lines. Trimmed front fender. Cut and fold rear fender. Rear JCR cut n fold bumper with tire carrier. Interior metal console bracket upgrade. Interior LED dome and courtesy light's. K Suspension headlight harness upgrade. Novak Cable T/C Shifter. Less than 150 miles on gears, ball joints, brakes, 231J Transfer Case, rear shaft. A/C work's but is original compressor. No heat. Heater core is by-passed. Never leaked inside cab. There was just a faint smell when A/C on so i assume a pin hole in the heater core. There is no headliner or plastic interior trim except for the console. Plan's were to cage it and box in the back wheel well's to trim more. No carpet in cargo area. Plan's were to move the gas tank up and sink it into floor and then spray liner the interior. Thing's that will go with sale. In storage not installed. JCR gas tank skid i had on but removed. TNT rear u-bolt eliminator with 1" lift. Hooligan's front and mid stiffener's, M.O.R.E. 8.8 swap kit plus there emergency brake cables, Front B/B spring spacer, Skyjacker drop pitman arm(found when digging thru my stuff in storage and forgot i had it. Was on my 97 Cherokee when i had bought that one new wayyy back in the day. I think it's for the 6"/8" lift). And parts to redo the cowel air induction setup. Currently sitting on 16x8 Streetlock's. I've got a stack of Orielly's receipt's and other receipt's. Documented oil changes. I bought another project and i can't juggle two, so this will be going to a good home.
