test
Ben H
Fresno
I need to clean out my jeep, garage and storage unit. I’ve priced this stuff to move quickly, so take advantage. The smaller stuff I can ship pretty easily, but the larger stuff will need to be picked up or dropped off. I head to through the Bay Area, Napa, Sonoma, Sacramento about once a month, so we may be able to work out a drop off or what not. If you want to buy a lot of this stuff (bulk), I’ll come down on the price significantly. Unless otherwise stated this stuff is used and may need new bushings. Some of this stuff is still on the jeep, and will be pulled off in the next couple of weeks unless there is interest. If you’re a homie, I’ll cut you a special special deal. I’d be willing to trade for 2” air bumps or gift certificates for Tom Woods or other stores. On the axles, if you want to buy the entire axle let me know, we’ll work something out to get these out the door.
All of this is coming off of a 2000 XJ, 4.0, Auto, 4 Door
1 NP231 Transfer Case, TeraLow 4:1, 2-Low, PORC SYE, Novak Shifter, With Spare Chain -$750
TJ Rubicon Dana 44, 30 Spline Inners -$200
Dana 44/30 CTMs -$100
Dana 44/30 30 Spline Outers, 30 Spline Unit Bearings -$300
Dana 30, Alloy USA Inners, Nitro 300m U Joints, 27 Spline Alloy USA Outers, 27 Spline Unit Bearings -$250
Dana 30 Ruff Stuff Diff Cover, with lube locker -$40
Dana 30 Lockright, with new set of springs -$100
Dana 30 High Pinion 4.56 gears (Spicer) with Carrier -$50
Stock Dana 30 Knuckles -Free
Dana 30 Brake Calipers -Free
Dana 30 Yoke Free
Chryco 8.25, 4.56 gears and carrier -$30
Chryco 8.25 Powertrax Locker -$100
Chryco 8.25 Ruff Stuff Diff Cover, with lube locker -$50
Chryco 8.25 ZJ Disc Brake Conversion -$100
2 Alloy USA 29 Spline 8.25 Shafts -$100
1 Yukon 29 Spline 8.25 Shaft, slighlty twisted splines (Good Spare) -$25
8.25 Yoke (2 of these) -$10
Big Offroad 4.5" HD FlexE Leafsprings (Maybe 5 runs on them) -$300
Currie XJ Anti Rock Sway bar (One run, damn near brand new) -$350
Currie Steering XJ, With Spare TREs -$200
Dodge Durango Steering Box, with Pitman Arm -$50
JKS ACOS PRO, adjustable coil spacers, with adjustable air bumps (brand new) -$700
1980's Dually Dana 70, 4.56 Gears, Open, Stock Shafts -$100
Dana 70 Disc Brake Brackets -$20
1979 Dana 44 HP 3/4 ton housing, with Ballstic XJ/TJ Brackets -$100
Right & Left Chevy Knuckles, flat top and drilled -$125
1 set of JKS Disconects (Not pretty, but work fine) -$25
Two Spare Driveshafts, 29"+/-, both same length (Off of a 2000 XJ with auto) -$25
Rubicon Express Control Arms, Lower Adjustable (slightly bent… more clearance :) -$50
Rough Country Control Arms, Upper Adjustable -$50
Rubicon Express Lower Control Arm Drop Brackets with braces -$75
Rusty's Belly Skid Plate -$25
Rusty's Cross Member -$25
Set of Rusty's 3.5 to 4.5" coil spings -$25
Set of RE 5.5" coil springs -$25
AJ's Offroad Square Sliders -$75
Nates Front Winch Bumper -$100
Fan Shroud -$10
Electric Fan -$10
Air box with modded snorkel that goes into cowl -Free
XJ front seats tear on driver seat side Free
Clayton Dana 30/44 axle brackets, 3 link, for highsteer (Brand New) -$300
2 Bilstein 5100 10" shocks -$25
1 set front JKS Bar Pin Eliminators -$20
1 set JKS Upper front shock mounts -$20
1 Farmboy Design Roof Halo (1st made, original prototype) -$300
A box full of misc XJ parts, shocks, interior parts, and other shit -Free
Another box full of misc XJ parts, transfer case parts, lights, and other shit -Free
One more box full of shit -Free
