SYE Quality story...
Here's my SYE story. FWIW.
Bot an RR kit from one of the many good 4x4 equipment retailers online. Good price. But shipped from Georgia, not the retailers location. Came in a OMIX-ADA box. Instructions were Rugged Ridge document which is easily available online also.
Easy enough to install. Did it on my XJ in the driveway. All seemed well.
Had the front DS out beforehand so as to isolate any noise/vibe issues to the back. What I did not notice right away was that TC got stuck in 4H once I shifted it to check linkage function before installing rear DS wrapping up the project. Shift lever would go back to 2H but the fork and rod would not. (Spring was correctly installed).
Removing the plug over the end of the shift rod on the SYE and tapping the end of the rod, it spring forward with ease moving the fork out of 4H back to 2H.
Here is what was happening: The recess in the RR SYE for the shift rod is misaligned. The rod was binding on the side of the recess just slightly. In fact so slightly that just a moderate tap on the plug would dislodge the rod and the spring would pop the TC out of 4H.
To solve the problem I loosened the five SYE mounting bolts and rotated the unit ever so slightly and retightened. Problem solved. Shift rod no longer got bound.
But as I suspected, the RTV no longer sealed and it leaked like crazy. So I took the whole SYE off and reinstalled with new RTV.
While having the SYE off, I put into my drill a mushroom shaped burr for woodworking and hogged out some of the soft aluminum sidewall of the recess inside the SYE where the shift rod backs into. This took away any chance of it binding on reinstall. Problem solved. Reassembly proved no binding and no oil leak.
However, this whole experience left me wondering about the quality of the main SYE casting. It mounts with no alignment pins, relying solely upon the five bolts to center and align the rear bearing and the shaft correctly with the front bearing of the shaft. The is about 1 mm of slop in the bolt holes, so the whole unit could randomly be correctly aligned, or probably out of alignment between front and back shaft bearings, meaning bearing axes are not the same.
Misalignment could cause noise, wear, vibes, oil seal leakage, or in my case, shift rod binding.
Just my story. Put it in your own pipe and smoke it FWIW.
