Ironmanandy
- North Carlolina
These are my Sway away bumps. 2" x4" travel They are the toughest built with the biggest shaft. Great for indirect impacts.
I was going to set these up for the rear of my race jeep inside the coil with the structural cans but am going with a bypass so I will bump with the compression valve.
The cans are made from .250 DOM and are machined for a perfect sleeve over the bumps. These can be put inside a coil or butted between tubes for a structural mount without concern. Note: pinch bolt and rings will need to be fabbed and installed once the setup is arranged.
The bumps are used but were rebuilt about 6 months ago I just freshly charged them to 180 psi. One pad ring is a little deformed but they work great. The bump pads are pretty much new.
Asking 300 obo I will ship
Call, text, pm or email
704 796 3502
[email protected]
704 796 3502
[email protected]
