im not gonna use this for the road, i am gonna lift the jeep, i might get the 700r. there is a member on here who installed the turbo tranny with some other v6, cant remember which one, but it wasnt the 4.0, and if i did get the 4.0 i would have to make room for it, because of he way my 85 was built under the hood. he had to cut the driveshaft, so i do know that, as for the mounts im gonna take them directly from the donor vehicle, ima get a bigger radiator and two fans to help keep it cool the factory one will work but i will run hotter than usual, um what other questions do i have, im not even worried about a speedometer, just tach, fuel, and temperature.
dont foget guys, im turning this into a paintball tank, maybe road worthy maybe not. and as for the transfer case ima try to get the one already on it the donor vehicle,
i appreciate the info "jeepm@n" i have a friend that said that the trottle body would work better for me with what im doing to with the jeep, im still working on trying to figure out my trasfer case deal, im having issues i dont know whether its my transfer case of something else going on, i have been talking on other threads about it, but i do know with the increase in power i am definatley changing out my transfer case, i just odnt know if i have to do the same on all the lines of the vacuum pump or what,
thanks guys,
ill keep you posted on the swap,
