XJ89JEEP
- Seattle, WA
I"m having issues with my 1990 XJ its 100% stock with 138k Larado package and a renix 4.0 auto-
The problem I'm having is that about every 3-4 times i start it, it turns over for a while then(it always ends up starting) it will rev to 3000 rpm and the immediately drops to 0rpm if you don't help it out by stepping on the gas to make it run. This happens when its either cold or hot. Most of the time it starts with no issue but it idles at 500 rpm (seems low to me). When it is running it runs great, no hick-ups or anything. I've had the jeep at the shop for over two weeks and the mechanic thought it was the EGR valve, so he blocked it off and it helped for about a week.(still currently blocked off) Then back to the usual problems. Also power seats and power locks don't work, and none of the dash lights work.
I HAVE REPLACE THE FOLLOWING PARTS...
plugs
cap
wires
rotor
temp sensor(on the block)
MAP sensor
TPS sensor
CSPS crank shart position sensor
EGR sensor
O2 sensor
I think that's it. all parts i replace with NEW not used parts.
I also pulled all the carpet and seats, thinking there was some corroded wires but not even a drop of moister, i also looked under the dash to see if i could spot something visually, nothing. I've check all of the fuses and they are all good.
The jeep has never been in any type of accident or anything. I've invested so much and still nothing, i have read forum after forum, post after post. I've done everything and tired that i could find online. any body have any more ideas that could help me out?
THANKS GUYS
plugs
cap
wires
rotor
MAP sensor
TPS sensor
EGR sensor
O2 sensor
THANKS GUYS
