- San Diego
I have tossed around the idea of getting a Griffin radiator. I have an all metal two row ready to go in. If that doesn't work as I'd hope Griffin it is. I occasionally wheel in the dunes in june.
Ding ding ding! Get a new fan clutch. If it doesn't sound like a 747, it's shot. Just put a hd one on my stepdad's xj and it'll blow the clothes off an Amish chick.
When are your fans set to come on? Since it goes down when you are on the freeway my bet is on an air flow problem.
Clutch fan Should not matter with dirtbounds e fans. Make sure they are pulling and not pushing.
First off, put a 195 thermostat it if you dont have one. Don't use anything else but a 195. Do you have ac? If so, does it work?
maybe your old thermostat was bad.
I was having the same problem with my '95 XJ. I had a CSF Triple Core rad and I tried all kinds of different fans (even the Taurus fan). Finally, what works is to return fans to stock and put in a Griffin radiator. It's expensive and it's a lot thicker than any other radiator I've seen for the XJ, but this thing WORKS! I have had NO overheating problems since installing it. Hope this helps...
I don't the fans are a problem, they are pulling air towards that motor. I believe they are set to come on at 195 and 210?
I was running a Stant 195 thermo with 13psi cap, without the thermo it has running at 210 with the A/C on the freeway.
I am sure I got 99% of the air out of the system, it is a 98 jeep. Do you think the condenser is blocking that much air? What about the catalytic converter being clogged, could that cause it over heat?
Ok, set the fans to come on earlier. Next get a 15 or 16 psi cap. Pull your fans and use compressed air to blow backwards through the radiator and condensor, just make sure you go STRAIGHT on to the fins or they will bend. When ever you replace a radiator you want to blow air backwards across the rest of the coolers to clear dirt out. I can't say if yours is or isn't blocking that much air without seeing it. If your AC works then I'd pull the condensor last. If it doesnt, well then yank that crap out of there.
Yes a plugged cat could cause this, but You would have more issues then over heating most likely. Another thing, not gonna cause this whole problem, but make sure your oil is full. It helps cool too.
If you want to do a flush I've used vinegar before. Added a pint of vinegar and ran straight water. Ran it like that for a few days then flushed it out. Only problem I found was it removed so much crap I had a hard time flushing it all out. Had to flush twice with water before I could add coolant.
Did you replace the spring in the Lower radiator hose when you changed it?
If everything is in good shape & it still runs hot There may be some kind of blockage, I would flush with one of the available long flush products & then see what happens.
Have you tried doing a good flush with a heavy duty cleaner? You could possibly have some buildup in the passage ways affecting cooling. I heard Ford has some crazy good cleaner that you can get from a dealer to super clean some older Tauruses that had cooling issues. But give a good heavy duty store bought cleaner a try. Even if it doesn't solve your problem atleast you will know the block is clean and it is one more thing you can rule out.
Confirm the actual temps by some other means ... IR, or a multimeter with a temp probe or something,
Test the CTS as per the factory service manual specs,
If the displayed temps are correct ....
-Is there too much eth-gly in the mix ???,
- Put another, new, t'stat in it ... stay with a 195* for the time being.
If you're using aftermarket t'stats ... buy the "premium" versions not the "economy" versions ... as" economy", relates to its price - NOT, how much fuel it saves you
Dont bother with 160* t'stats IMHO ... but since Jeep/Chrysler offered optional 180* t'stats for the XJ in their parts books ... there shouldnt be an issue with 180* t'stats
Its not good to run for prolonged periods with no t'stat at all ... too much flow. Much better to just knock the centre piece out as a short term, trail fix.
- Grab yourself a 15psi rad cap ... and make sure its sealing properly on the filler neck.
- If possible ... adjust the start temp of the fans ...
Begin with 180* and fine tune from there ... Adjust the higher setting down as required if nescessary.
- AW4 ??? ... still hooked up to the radiator ??? ... now theres a design flaw IMHO .. ..
Double check that all the cooling system stuff is operating correctly before moving on to heads and blocked cats ... its all just a process of elimination unfortunately.
"-Is there too much eth-gly in the mix ???"
I missed that one, are you running the correct mixture for your conditions?
This. Set your fans to come on earlier. Setting them to come on when the jeep is already at 195 or 210 is too late. Also use a 16 psi radiator cap.
Yeah I still have the tranny fluid running though the raditor, but will that really make a huge diffrence in cooling the whole Jeep? I am going to add a tranny cooler eventaully, but I was going to wait until I put new tranny in. With 202k miles on it I don't think I am going to make much of a diffrence now?
......................... I am filled the system with 50/50 pre-mix,
and the CSF rad I can only find a 18 PSI or 13PSI cap to fit properly. I ran an 18psi cap until removed thermostat. I was under the impression the high cap the higher boiling temp?
Yeah when I replaced the raditor I also install new hoses, clamps and flushed it with a heavy duty flush then I ran vineagar in system and let sit over night.
Did you transfer the lower hose spring from the old hose into the new one?
Most new hoses do not contain the spring & it needs to be transferred in.
..... but you need to consider - whether the tranny needs the warm up assistance, at a cold start, that the tranny/rad, heat exchanger provides .... in your operating environment.
If you fit one now ... it can only extend the life of the current tranny.
Have you confirmed the temperature with an IR thermometer? This has been suggested and I apologize if you have already answered.
