How many miles are on it?. Just curious, I didn't see it anywhere in the post.
Probably not relevant, or maybe misunderstood on my part.=====> Coolant levels are high, except when it boils over but I immediately refill what was lost after it cools down. <=======
I hate to sound like I'm just repeating someone, but have you really looked at your cat? You can troubleshoot those with a vacuum gauge. My 92 (yeah yeah, not obd-ii, but whatever) had a plugged cat with similar issues. I would overheat for no reason at all even with nice new cooling equipment. Once the cat was fixed I stopped overheating. That was in New Mexico on hot days with the AC on.
I believe this guy is from Austrailia. Not sure how his temps. compare with Vegas. I think they measure their temps. in Celcius over there anyway lol.Restrictor would be fine in a cold environment, but not in Vegas. A good quality high-flow thermostat is what he needs -
http://www.summitracing.com/parts/emp-309/applications/make/american-motors
Put it a 2 core all aluminum radiator .
You want wide tubes. 1" ideal. 3/4" not bad .
Wire in a 99+ Efan. Wire it to a switch on the dash . Run it
All the time if needed.
Run a mechanical gauge to inside the cab to verify temps off the t stat housing.
High pressure cap.
Are you sure gauges and sending unit are good ? The mechanical gauge above will ensure your readings are right .
on the original engine?. Have you pressure checked the cooling system?. I have a 2000 xj w/ same mileage. I think we both need long blocks. Bwah.
what cap are you using?
