IRPancake
- Oviedo, Fl
Going for another trip at the junkyard in a few days and wanted to double check everything before I go, its sort of far away and you have to pay stupid entrance fees and stuff (but they have a ton of cars!)
- I read that the tie rod ends off a 93-98 grand cherokee swap direction, true?
- Do the balljoints off any cherokee (2wd/4wd, earlier/newer models, or even different models) matter?
- Also wanted to double check that the steering stabilizer would work off any 93-98 grand cherokee as well (there was one at the junkyard with a nice one).
- Another big question I had was about the trackbar. I found one at the junkyard that looked like it was in excellent condition. I went to remove it but I removed the cotter pin and nut and the thing wouldn't come out. Is there a trick to get it out?
- aaandd, I read the brake booster from a 96-97 cherokee is an upgrade. Is it a dual diaphram or just better some other way? and is there any trick to swapping it like the grand cherokee booster?
thanks in advance!
thanks in advance!
