Couple different questions here, I'll try to keep it simple.
So last December I had some pretty loose steering. I had 3 tie-rod ends replaced and passenger side wheel bearing. Now I'm back to having similar symptoms, but the slop seems to be in the steering shaft itself (piece that connects the wheel to the steering gear/box). I can grab it with my hand, rotate it, and see the wheel moving inside the car. The visible movement in the wheel seems to be about the same amount of slop I feel when driving. I noticed there is a joint in the steering shaft, with a small u-joint, but that u-joint doesn't seem to be loose.
Is it possible for components inside the box itself wear out or become loose? If so, what are the remedies? Any other parts I should be looking at? I've checked the tracbar, it's tight. Could the TRE's be worn out again already?
I've got an '01 XJ w/ RE 3.5" lift + 1.25" spacer/shackle. 33's, Long-arms, RE Tracbar. Stock steering components w/ the exception of an Alumaflex tie rod.
Thanks guys!
Thanks guys!
