old_man
- Loveland, Colorado
There are two main variations in the XJ boxes. There are countless other variations to the internals that if you haven't gone through a bunch with calipers, you would never see such as the fact that there are different turns lock to lock on boxes. I still haven't figured out any rhyme or reason as to which box has what number of turns.
The renix box uses two double lip seals on the pitman shaft. Both seals have two lips. The HO variant uses only one single lip seal on the pitman shaft and a thin single lip seal outside the snap ring to keep the dirt out. There is also a difference in the input shaft configuration and seals.
Lately the HO variants are seeing a horrible failure rate on the replacement pitman shaft seals. I have seen roughly 50% fail. To that end, I am setting up to CNC machine the newer boxes to accept a different seal configuration similar to the Renix box.
While I prefer using the Renix boxes for several reasons, they are getting harder to find.
