Ronbo
- San Marcos, CA
My Lares-rebuilt box is working great.
I did maybe half a dozen times, I'll go do it some more.
What type of fluid did you use?
I wrapped it all up today and took it for a test drive. It was considerably tighter, but I did feel a dead spot on occasion. Nothing regular. I still have some clunking, so I do need to take a look at everything from underneath while someone steers it to be sure everything is tight. I was able to straighten the steering wheel then when I put on the pitman arm it fit almost perfectly with where the TRE was set from the old box, so I can't imagine I hurt anything. I am pulling right, so I need to get that attended to.
Could a bad steering shaft - from the firewall to the box - cause clunking or any additional play in the steering wheel?
Overall, I think it was a good move to install this box, and I'll know more next time I open it up on the interstate.
Regular ps fluid should be fine.
It does sound like the ps pump is faulty, wouldn't be my first guess but if rpms improve it then it seems like the pressure is insufficient.
how does it sound?
I've replaced so many ps pumps and gears I'm trying to think of anything like this.
