foxwar71
- Foxboro, MA
And Vetteboy79 did exactly what you are saying and what I am saying. He found a nut that fit on the box and machined it to perfectly fit inside a pillow block bearing. Then pretty much created the PSC brace. Probably the best way to do it, but the exhaust clamp method I posted above is a close second.
He actaully never got around to doing anything more then making the pitman arn nut :laugh3: Somebody else in the NAC now has it with intensions to make the brace setup. I would also like to build on for my jeep as well, but with the hydro assist I have now I probably won't get around to it anytime soon. I've also plated over the factory sway bar bolt holes so I'll have to come up with some other sorta removeable mount.
Another great steering box brace that should be brought over to this thread is the one that Larry the Dog built for his jeepspeed project. Supports the box itself, the sector shaft, and ties to the other framerail. Here's the post from his build thread:
Im using a Dodge Durango Steering box. It bolted right in.
I started on the steering box stiffener. I went about it a little differantly.
Top plate.
Bottom u-bolt clamp.
Steering box side bracket welded.
Passanger side frame mount
Stiffener done.
Mounted.
