Red91Laredo
- Portland, Oregon
I am planning on installing a Durango steering box soon and figured this would be a good time to install steering box braces (the kind that 'sandwich' the unibody between two plates). A few companies make these now, and they all look plenty beefy, so I'm sure any of them will work equally well (it looks like C-Rok is no longer in business, so I'm looking at the Iron Rock and JCR braces). What I can't seem to find out is if they're going to interfere with OEM tow hook brackets. I snagged the OEM tow hooks from the junkyard a while back and I want to install all this stuff at the same time. As far as I can tell the driver side tow hook bracket and the outer steering box plate basically need to occupy the same area.
I'm hoping this is as simple as installing the outer steering box plate first and then the tow hook bracket on top of it, but I don't know if that will mess up the alignment of other things. The OEM tow hook brackets have the bumper brackets welded onto them, so I assume that spacing the bracket over 1/4" or so (the thickness of the steering box plate) will cause the bumper mounting holes to no longer line up. I'm hoping I can just 'adjust' things with a BFH if needed, but I figure someone must have installed these two parts before and can tell me what they had to do to make them work together... any advice?
