The pinion depth is specified, not the amount of shim to get to that depth. So if you don't have a starting point (previously installed gears) or pinion depth tool this number doesn't help a whol lot.
Almost. Thats for a LP D44 rear.
and the oil slinger too.
The baffle is stepped and goes under the bearing cup. and its usually .020". and is not included in the in the shim requirements.
Yukon gives a starting shim of .065" for the HP D44.
The oil slinger is .030" typically and then another .035" under the cup.
I tend to start out at .060" though and have had good luck.
Lincoln said:
.042" including the oil baffle.
Also I've been leaving the oil baffle out of the stack and replacing it's thickness with shims. It makes it easier to hammer the race back out.
Ryan, I just slap them together and don't pay attention to what I'm putting in there.
One other thing I do that may be helpfull. If I guess light on the carrier shims on the first try I will wedge it over against the pinion and check the gap withe the feeler guage then drop .010" from the ring gear side and add .015" to the other. That usually gets the back lash close and a light preload.
