werewoulf3
- havelock, nc
another dumb question......its has to be welded in doesnt it?
Ok since the yoke is welded to the shaft will I need part 607 or part 617? Will I have to weld in part 607 in place of the one that is stock on the shaft?
the yoke you are looking at doesnt have to be welded in. no welding has to be done. 607 is the whole yoke, 617 is the seal kit. the yoke that comes with 607 DOES NOT WELD IN. you wont have to cut anything. just take it apart, and look at it, look at diagrams online. its REALLY not that hard.Ok since the yoke is welded to the shaft will I need part 607 or part 617? Will I have to weld in part 607 in place of the one that is stock on the shaft?
Or if you have the money.... Buy a replacement drive shaft from the parts store that has a lifetime warranty. Then you don't have to worry bout taking it apart and messing with it. Happens again or anything else happens you can just replace it under warranty. lol. That's what I ended up doing as I had the same issue on my 89'.
driveshafts shops will rebuild your whole DS with new centering assembly and 3 new u-joints, and balance it for 100-150 bucks. worth it if you dont have a solid workbench and press.
