RidgeRunnerXJ
- Brighton(ish), CO
I have 2 speedometer gears, a 35 tooth (part# 52067635) and a 37 tooth (part# 52067637). Both are used but in good condition. Both are the "short shaft" for '93-'01 XJs and up to '06 TJs. ~$25 each
There is a chart to see what speedo gear works for each tire/axle ratio combo here: http://jeep-xj.info/HowtoSpeedoGears.htm
Also have a speedometer sender, I believe it will work in both np231 and 242 cases. Came out of a '99 np231. ~$25
Pick up in Broomfield or Thornton. PM your # if you want pics.
