Jip
- South Carolina
Hi All,
It's been a while since I lurked through . I finally got back into a project XJ. Its a '98 Classic 2WD. Its got some issues that I'm working on.
One issue is with the non-working speedometer and odometer. I tested the cluster, checked the VSS, and speedo gear attached to the VSS. After removing the VSS and speedo gear, I looked inside the opening to the transmission. I expected to see a broken speedometer drive gear within the transmission tailshaft, however ....the drive gear is nowhere to be found (I didn't even find any broken bits of plastic).
So, how difficult is it to replace this gear? I assume I have to pull the tailshaft. Also, where can I find this part?
Any advice is appreciated, thanks!
