fsupaintball
- W of Denver
Boy, I sure seem to have a lot of issues recently.
Today on the way home from work my speedometer started jumping up randomly. When I started my hill climb home on the interstate, the throttle started completely cutting out and then coming back on repeatedly, very quickly, along with the speedo movement.
My first thought was "Throttle Positioning Sensor" - I had this problem last year and a new one fixed it. So I pulled over at an auto parts store and replaced it, but it didn't fix it.
Not sure what to do now. I'm thinking of trying ANOTHER TPS (I may have gotten a bad one). Here's a couple things that could be contributing:
1. My engine runs real hot, which I'm sure helps kill a TPS. I'm working on fixing that. But when I started having the issue with the speedo today, I was running at normal operating temp.
2. My wire harness is a bit stretched out since I swapped in a 97+ style manifold a couple weeks ago. Especially the wire going to this sensor (that pic is not my jeep). I think that's the MAT sensor? I don't think that sensor usually causes these kind of problems though.
3. I had to pull out my PCM the other day. I've seen a report that the stock screws that hold the PCM in may be a bit too long from the factory and can come in contact with the circuit board, causing shorts, causing similar problems. Maybe I'll try backing those off a little.
Any bright ideas?
Any bright ideas?
