XJRedneck said:
JaysXJ: "Sorry to say, but, AMC or Jeep never produced a Flat-4 cyl. or a H.O. V-6..."
OK I'll admit I screwed up when I said that Jeep put V6 H.O's in some of their rigs. But growin up, I learned that a Flat 4 is the same thing as an Inline 4.
So if I'm sayin it wrong then I'll try to remember to go with I4.
Eagle: "the 2.5L I4 engine in the XJ should be delivering 25 to 28 MPG, not 16."
Eagle are u sure its suppose to be 25-28 MPG?
Cause if it is I'm really getting screwed on my mileage....
Cherokee motors were 2.5L inline 4 and GM 2.8L V6. in 84-86. In 87' the 2.8L was replaced with the 4.0L and they also continued to use the 2.5L untill I think 2000 when they only produced 4.0L units for the US market.
The 2.8Ls were far from H.O. units, but NOS (new old stock) engines GM didn't want (IMO). As all the 2.8Ls in GMs were TB injection. The 2.5Ls didn't start to get much over 20-22 mpg (depending on transmission and electrical options) untill port injection came around. After all, they were yanking around 3,200# of Jeep around at 90hp.
So... back to your original question: All Cherokees are OK by me. I have owned a 85' 2.8L manual, 86' 2.8L auto, and presently own a 98' 4.0L auto. It's all good.
Some things to look for.
* Fuse panel on a 84-96 MANUAL units. Sometimes the Clutch master cylinder leaked. When it did, most often it was inside- all over the fuse block- killing the fuse block and eating the contacts. Guaranteed electrical problems.
* Oil in air filter. Often caused by a Crank Case Ventalation system which is plugged. Annoying, but "minor" maintance item.
* Check Floors, esp the Passenger side floor. Often the heat shield comes off on the cat causing the floor to rust out from the inside due to condensation.
* Seats. Make sure the drivers side seat frame hasn't started coming apart. Look under seat where seat mounts to sliders for cracks.
* If you intend to off-road the unit, starting in 2000, the front axle was usually a low pinion model. All others were high pinion. Also 97 and up units sometimes came with 8.25 rear ends. Strong axles, but you gave up 1/2 an inch at the pumpkin in ground clearance.
* 84-91(?) front axles were "disconnect" front axles, which meant that the passenger side axle has a vacuum motor on it to engage or dissengage the front axle. Be sure hoses are in good shape.
* High idle issues. Annoying maintance problem.
* I prefer part time 4WD to Full time, but that's me. PT 4WD shifter goes '2WD, 4WD, N, 4LO'.
* 97-99' models had a factory recall to move the airbag controller from under the Drivers seat where it could get wet and deploy the airbags. Make sure it was complied with.
There are a host of other things, but they are all maintance problems. Most Cherokees if they are maintained last well into the 200K mark.
