terryd
- Elk Creek/Covington Va
Here's some shots of some stuff I've done to the Jeep in the last 6 months or so.
I trimmed the air dam off the front bumper and cleaned up the license plate holder a little bit.
My new Bastard Packs. They are made with longer (long bed) S-10 leaves under a Cherokee main with poly bushings installed. The front of the 2nd leaf is under the main eye and the rear of it is much closer to the shackle eye than the old set. Hope these last longer.
I had stretched the YJ lines I had on it, so I decided to use some C-1500 lines like I had seen elsewhere. I had to make a bracket for the frame end and wrapped it in PV tubing to keep the shocks from rubbing them.
Also, I'm carrying my spare tire laying flat in the cargo area. I was a little leery of the stock tie-downs that are riveted to the floor without any extra support. I bought these at Tractor Supply for $1.29 ea. Rated at 1200LBS.
Drilled the old ones out and then drilled the extra hole in the floor to mount these.
Also while there, I was wanting to move my High-Lift inside off the roof rack. Matt came up with this idea.
I think looks pretty good back there. I feel a little better about having my little girl strapped in back there now that the spare isn't going to rip lose if something should happen.
