winkosmosis
- Maui, Hawaii
Why do you care about reversability? Are you really going to try to sell it to some granny for $1000?
The LA is probably the preferred but costs more and there is no return from them.
Check these out
http://www.ironrockoffroad.com/Merc...en=PROD&Store_Code=IROR&Product_Code=IR-X_LAK
I'm running these long arms and they clear the LCA mount so I can put it back to stock, or change to whatever set up I want.
I have the IRO long arm set up on my DD with 5.5" and 35's. Rides just like a stock cherokee, nothing funning from the 3 link set up. Had it on a little over a year and a half. Best deal i could find for a long arm.
its a 3 link system. Look at the Pic. One upper arm that is attached to the lower. and one single lower.
OK, so with DB's I loose 4 inches at the rear LCA mount but I lifted it 5 so I will be 1 inch over stock. Witch one LA's or DB's rides best and will resist the DW the most? Witch set up would you like to see the most if you were looking at a used XJ? I have seen the 3 link and it probably flexes mor than I would ever need. I leaves one side unsupported on the top and, I think, might not be as controlled at fwy speeds although I am sure there are many that have no problem.
My rear shackle angle is, from the body mount down, at a little past 6 o'clock, not straight up and down but not far from it. It is grease-able and 1.5 longer than stock to add .75 lift. If it was pointing farther back it might be better but it is headed in the right direction. Has anyone ever regretted going with LA's ? What would be the reason? What if a LA had clevite bushing at the body end? Might ride better. I know it might not flex as much but SA's have them and seem to do OK.
