- Duck River
What'd you say? I can't read it because the text is so tiny.
If someone can tell me how to adjust size on imgur I'd love to know??
Thank you sir!!Hi John,
Double-click on desired image from your Imgur images page.
Select size from options on the right, bottom (large thumbnail is good)
Click Copy at 'Direct Link' above (this copies the image address)
Go to thread, select 'Insert Image', in pop up window add link by pressing Control V simultaneously (paste), Click OK
here's your pic in Large Thumbnail size
Save hitch/tank skid nutstrip for me, please.
Dana 30 carrier complete with spider gears and bearings, ring and pinion. Ring gear is still bolted to carrier. 3.55 gears from a 1991 xj
Stock front speakers from a 2001 xj
Stock pitman arm from a 2001 xj
Stock red bumper and end caps from a 2001 xj
I will take the pitman arm if you still have it
Couldn’t find the Karma thread.
2014 JKUR.
- stock rear 44 axle shafts. No damage had a slight leak on passenger side. These are Rubicon 44 shafts (2 different lengths). If your running a JKUR rear 44 these would be good replacement or Trail spares. Just pulled them today
- stock rear lower control arms. Good condition.
If anybody has a need, I need them gone
Wrangler tires. 255/75r17
Set of 4. Tires only, no wheels.
Tread depth is good, probably more than 50% all even. Tread is "rough" from being spun in gravel, but no issues using for daily driver or offroad.
Free to good home.
No problem. Yours
Parting out 2000 with front-end damage; I didn't want to spam the Karma thread with too much crap, so I posted it over at https://naxja.org/forum/showthread.php?p=246595322#post246595322
-Hildy
I also have a pair of KC HiLiTES 124 SlimLite halogen, just the lights though, need to get a wiring harness.
located in LA by the grove
